kopitech
asked Aug 30, 2010 at 9:13am
Hp HP Color LaserJet 2500L
HP color laserjet 2500L that only prints yellow
i have two HP color laserjet 2500L with the same problem! they both will only print in yellow, but not everything that is sent to them. the demo page is only in yellow, but when i go the preference print and i put it to print only in gray scale it will print black, i have realigned the carousel and check the toners and the imaging units but still having the same issues.
ANY SUGGESTIONS?
I have now had a printer come in for repair with exactly this problem. It only prints in yellow when it is set to automatic colour selection but will print everything in perfect greyscale. I have replaced the formatter which made no difference and the toner cartridges all work perfectly well.
Any ideas anyone, please?
by unknown on Dec 1, 2010 at 6:28am Add comment
Hi Moe, thank you very much for this solution. I have replaced the small foam pad and it works well. However, I cannot understand why this should be a problem. We had a similar problem on a Magicolor 2200. Can you explain the science behind this, please?
by unknown on Dec 10, 2010 at 2:27am Add comment
With the pad deteriorated, it leaves a sticky residue. The solenoid acts as the carousel brake. If it stays actuated because the plate doesn't release, the carousel continues to turn and the other colors don't get applied.
by moe on Dec 10, 2010 at 8:01am Add comment
by moe on Dec 10, 2010 at 8:02am Add comment
I have this same problem where do I find the solenoid on this printer. Thank You.
by mexistamps on Mar 27, 2012 at 5:57pm Add comment
The solenoid is located on the top right side of the printer. It's just behind the back part of the access door. You have to remove the top and right side covers to access it. There is also a bit of disassembly of metal pieces covering it before you can get to it. You have to scrape it off and replace it with a thin piece of sticky back felt for it to work correctly.
by moe on Mar 28, 2012 at 9:28am Add comment
