ploth
asked Jul 12, 2010 at 7:54pm
Lexmark Lexmark Z 80
Reset 80 Maintenace Error - Fuser on Lexmark C920
I have put in another Fuser - but the error remains and the printer won't do anything. How do I reset the printer (and how do I enter maintenance mode) or how do i set the fuser to reset the printer (ie slow blow fuse)?
Thanks in advance :)
Power off, hold Select and Return, power on, when performing self test shows on display release buttons. You should see "config menu" on first line and "reset maint cnt" on second line. If "80 scheduled maint" is showing you may have to press go to enable menu. Press menu until you see reset maint cnt and press select.
Hope that helps...
by unknown on Jul 13, 2010 at 5:34am Add comment
Hi, I have the same problem with the fuser, I installed a new fuser and the same message appears (80 maintenace error)
I try to entry in the config menu, but i can´t.
What is the return button?
I apreciate your help.
Thanks and best regards.
Jean
[email protected]
by impremara515 on Jun 8, 2012 at 12:43pm Add comment
Hi, I finally i entry to config menu, but the reset main count don`t appears in the menu, i try to understand your words "you may have to press go to enable menu. Press menu until you see reset maint cnt and press select"
but i can`t understand well, i try to do pushing the menu button but nothing happends.
I need to reinitialice the fusro values.
Jean
[email protected]
by impremara515 on Jun 9, 2012 at 1:01am Add comment
