infinet2000
asked Dec 15, 2009 at 7:55pm
Hp HP CopyJet Color
remove and check cartridge error HP OFFICEJET 6110
I have cleaned all the mylar cartridge areas using a cotton swab and alcohol. Reinserted my color and black cartridges back into their slots more than several times.
I read through the forum on all the "remove and check cartridge" responses,and tried out each method to correct this error. I still can't get rid of the message. None of the wires are bent and everything looks intact. I can't figure out why I keep getting the error message. Grrrrrrr. I need my printer!!
PLEASE HELP!!! THANKS.
It sounds either like a clogged or dried printer cartridge, or a
printer cartridge recognition problem (usually that gives you some error
code though). Try this tool
http://www.printcountry.com/troubleshooting-guide.asp
by alfredjr18 on Dec 15, 2009 at 10:46pm Add comment
hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
by wazza2470 on Dec 23, 2009 at 6:29pm Add comment
Removing the spring wire worked like a charm for me
by unknown on May 4, 2012 at 9:51am Add comment
I have tried the fixes mentioned but still cannot get my 6110 to work. It ran out of black ink and having replaced same with two new catridges cannot get rid of the error " remove and check cartridge". Can anyone tell me how to check the ribbon cable connections and clean thr print head?
by Trevor Grout on Nov 5, 2012 at 9:48am Add comment
