rhn0327
asked Oct 29, 2007 at 1:26pm
Laserjet 4350 58.20 Error
Anyone ever see a 58.20 error? It is not in the service manual and all the help says is power the printer off and back on. Googling 58.20 gets absolutely nothing related to Laserjet printers. Thanks for any help!
Bob
It's in the manual. It is an air temperature sensor error. Remove the left side cover and the bar that goes accross the fan has a wire coming out of it that goes to the power supply. Disconnect and then reconnect the wire and see if that makes a difference. If not, then you need to replace the air temperature sensor.
by dmzcompute on Oct 29, 2007 at 3:17pm Add comment
Edit.. NM.. DMZ got it before I could post and double check..
by Danccc on Oct 29, 2007 at 3:22pm Add comment
I will give this a shot. The service manual I have only lists 58.2, 58.3 and 58.4. It says 58.2 is the air-temperature sensor. Not 58.20. But I will give it a shot. Thank you.
by Anonymous on Nov 13, 2007 at 2:40pm Add comment
If you meet the same error (58.20) on the HP4250. It will be treated the same way for the above dmzcompute's solution.
by Anonymous on Feb 19, 2009 at 2:08am Add comment
-1
if what dmzcompute does not fixed your problem then you need to replace the power supply.
by jalvarado on Nov 26, 2013 at 5:18am Add comment
