XFact0r
asked Jan 29, 2007 at 4:57am
Canon PIXMA MP150 service manual
I just got the service manual for PIXMA MP150. Anybody interested? E-mail me.
Hi - grateful for advice on my Canon Pixma 150. The other day I replaced the ink cartridges as usual. Now whenever I try to print I get the "E3" error indicating that there is a paper jam. However, there isn't and never was. I already turned off the machine and unplugged everything, then set it all back up again. I've poked around the machine a bit, but there isn't anything in the way. Opening and closing the cover doesn't reset it.
Thoughts?
Thoughts?
help! no paper jam but the printer keeps saying error 3. I have taken the thing apart and there is not a paper jam. there was a paper jam when the problem 1st occured but now there is not a jam and I still have E 3. what is the process to achieve a working printer again?? Please post for me or send to email.
- Anonymous
- Anonymous
The simple answer is, we havent fixed this problem!
I contacted Canon support, who responsed............
"Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
Please be advised that if the MP 150 is displaying the letter E followed by number 3, this would indicate a paper jam.
However, if it is flashing E, then 3 and then another digit, an error requiring servicing might have occurred.
Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn ON the machine. If the same error occurs, contact a Canon service representative.
Please find below a list of authorized service centers for your device and some packaging instructions:
Packaging advice for returning products:
- Take note of your serial number
- Pack it very carefully and make sure it is covered by insurance
- Please ensure you enclose the following:
o The bill of sale and/or warranty details in case the product is under warranty
o Details of the fault/instructions for repair
o Your name and complete address details for the return of your product
Electroversal
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582 023
Fax: 01582 582 087
Web: http://www.electroversal.com
Bryan S Ryan (Printers and Scanners)
Main Road
Tallaght
Dublin 24
Tel: 01 404 7900
Fax: 01 452 4845
Web: http://www.bryansryan.ie
Yours sincerely,
Canon Support Centre"
We have decided to save ourselves the time and expense of getting it serviced and are buying ourselves a new printer!
Sorry I could help any further!
Rockbanks
"Dear Customer,
Electroversal
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582 023
Fax: 01582 582 087
Main Road
Tallaght
Dublin 24
Tel: 01 404 7900
Fax: 01 452 4845
Yours sincerely,
Rockbanks
I'm getting an alternate E & 5. Recently fitted new ink cartridges.
Same here, alternating E & 5, after I fitted new ink cartridges. Does anyone know how to fix this?
Regards
Bertram - Anonymous
Regards
Bertram - Anonymous
you might have left one of the cartridges out
- Anonymous
- Anonymous
E5 and E6??????? what does this means???? Please someone answer i need my printer back
Thks =)
Thks =)
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E29 - EEPROM error
E42 - Scanner error
how can I fix the error code E27 Waste ink absorber full? Can I fix this myself or bring it to the service center if there is? thanks. - Anonymous
I also have alternaring E and 5 flashing. The belt is loose is this normal or could it be part of the problem. This occured when I changed ink cartridge. The carriage would not return to far left where I could remove so I forced it over. OOps.
quiero saber como se repara este defecto ya qui ami me ocurre lo mismo saque los cartuchos a la fuerza - Anonymous
I'm getting the E3 message. I know it means a paper jam, but the paper isn't even getting into the printer! It feeds skewed, and won't go in! HELPP! I've tried cleaning the paper rollers, but it's still messed up!
make sure printer cartridge socket is clear...
Printer screen shows "E" "2" "7"
Pop up screen on computer shows: "Waste ink absorber is full. Contact service center for replacement of waste ink absorber."
Dears,
I need Service manual PIXMA150, could you give me the manual please,
thanks
Husnib
thanks
Husnib
please send me a copy of the service manual for pixma mp150.
This will be very helpfull
Could you send me a copy of service manual
I would be greatfull:)
Thx
Thx
I've got it, email me at [email protected]
i was wondering if u know how to reset mp198 or get rid of the e=27 on mp198 please email me just bought this priner a couple of months now its displaying e27 email me at [email protected] - Anonymous
I would be interested in the Canon Pixma 150 Service Manual
I do not know for sure if you can help me with my canon 150, but I'm willing to give the manual a try.
You see everytime I go to print on it, it says paper jam and the paper would lean to one side. I sure hope the manual has an answer to this problem.
Please let me know how to receive this manual
thank you
Carlos
thank you
Carlos
Hello i just got a Cannon PIXMA MP150 and hooked it up to my pc with vista , and i have no paper in it, i have ink in it..... the alarm led keeps beeping and im getting E 2 3 , over and over and i cant do anything..... what should i do?
Hi.
I'm interested in this service manual.
I send email you, but it still is without answer.
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
email add: [email protected]
Direct Printing
E22 Carriage error
E29 EEPROM error
estoy interesado en que me mandes el manual de la impresora canon pixma mp150-160, tengo un problema que resolver
gracias
gracias
hello,
can some help me with a pdf version of the user guide or service manual because l would like to print and read
thanks
thanks
I get the E5 error flashing, and i have the correct ink cartdriges in it but it says they are wrong or installed wrong . I know they are correct but why is this message still flashing ? Do i have to reset my printer in some way ?
Anyone else have this problem and were able to correct it ?
any help would be greatful :)
Did you solve this problem with E5. Can you advise me?
- Anonymous
- Anonymous
lolol
Can i have the service manual for mp150 plz.thank you
I have this manual. Email me.
Yo tambien estoy interesado en que me mandes el manual de la impresora canon pixma mp150, tengo un problema que resolver.
Gracias
I need Service Manual Canon Pixma 150. I have many problems.
Gracias
all you people saying i have the manual email me, why cant you just post it so everyone can have it :@ who ever needs the manual you can get it from here
http://safemanuals.com
the link is for USERs Manuals..these are found easy on manufacturers website.
I am needing the SERVICE Manual for cleaning the waste pads.
the triangle with the symbol in the middle like lighting won.t go off.any ideas?
What I found out through trail and error is that I had to have BOTH the black and the color ink cartridges in before it would go away. I had wanted to only use black ink.
Other than that, just make sure that ink cartridges have both been put in their place by being pushed in with a slight incline down towards you and then clicked into place by being made more horizontal by pushing up the end closest to you up.
That's what worked for me. Reading the manual did not help me with any more information than is given by the other posts to this site.
the printer uses all colours to print black normally.
somewhre in the software and tell it to print black only..or draft.
the users manuals are useless
Error code E-2-2, comes again and again whenever printer is put-on.
Some times error E-4-2 also appears.
Please Help.
Please Help.
Ho cambiato la cartuccia alla Pixma 150, mi da errore E6. Non riesco a resettarla. Come devo fare? Aiuto!!!!
google it!
If you are getting the E3 error and there is NO REAL paper jam I just figured out the solution! It's a bit obscure but what you need to do is simulate a paper jam (it thinks there is one, so give it one!). I just shoved paper inside the printer (after lifting the hood up) so that a real paper jam would occur. When it starts trying to feed the paper through and its getting jammed lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Hope this helps.
Hope this helps.
I had the same problem on a customer's printer today and there wasn't any jam. This forum being the only place where you can get a fix found this thread. Your solution looked stupid enough that it might work and sho' enuf it did. - moe
I would like to receive a service manual on the printer mentioned above, can yoy help me. Thank you in advance. Per
hi ! I know it is old message but if you still have the service manual please mail it to me !
Thanks in forward !
Stojan
Thanks in forward !
Stojan
Free download link http://rapidshare.com/files/350442575/canon_pixma_MP150.rar
downloading link for Canon PIXMA MP150 service manual.
http://rapidshare.com/files/351374473/canon_pixma_MP150.rar
Thank you for the link to service manual! - unknown
helo...i am new here....
can someone help me how to fix E42 to MP160???
please..so urgent to me..:(
como posso corrigir o erro de código de absorção de resÃduos de tintas, E27 completo? Can I fix this myself or bring it to the service center if there is? Posso corrigir esse mesmo ou levá-lo ao centro de serviço, se houver? thanks. obrigado
Can someone tell me how to scan a document onto my computer? When I click scan, it automatically prints it! :/
You have to install it the cd in your computer. - Anonymous
Can I have a copy of it?
Thanks in advance.
Thanks in advance.
please sent me the manual (pixma 150) i have a problem with paper and with the ink. i can not reset the system
absorptiekussen canon printer pixma mp150 is schoon gemaakt. hoe krijg je de error E27 verwijderd, zodat je weer printen kan?
A service manual isn't going to help any of you if you're too stupid to see the links above and download the damn thing instead of keep asking for it.
Sheesh!
Sheesh!
i need service manual.
please send me
thanks very much
please send me
thanks very much
please send me
thanks very much
please send me
thanks very much
how could i download my printers manual order for it to work in my computer anybody know? reply me
please
please
RCHELECTRONIS There are TWO count them TWO DOWNLOAD LINKS FOR THE MANUAL in this very thread. You just need to read.
sayra Canon has a site with that info.
hola nececito y me urge tu manual lo busco para la mp 160 pero me imagino q ese tuyo me puede ayudar el mp150
espero tu pronta respuesta grasias
My printer is indicating a paper jam (code 3) but I have threaded a card stock weight piece of paper through it 3 times and it still indicates E-3 when I ask it to print again. Also, the printer problem icon does not show up on my computer screen like it usually does. I have shut the computer down and the printer down and restarted several times but that doesn't seem to clear it either. Would love suggestions! many thanks, nanckers
delete printer from your computer.
re install..
OR
with strong. bright flashlight look for a SMaLL piece of paper
re install..
OR
ÍßÊÎÈ ÁÚÐÇÎ ÄÀ ÏÎÌÎÃÍÅ!!!!! íàøèÿ å ñêåíåð + ïðèíòåð, êîëêîòî è ïúòè äà íàòèñêàì êîï÷åòî íå ñå ïîÿâÿâà ïðîçîðåöà íà êîéòî ìå ïèòà êàê èñêàì äà ãî ñêàíèðàì. ×óäåõ ñå çàùî, ïèòàõ áàùà ìè è çàïî÷íà åäíà äðàìà...... "ïðèíòåðúò ñè îòèäå, èçãîðè ãî, ðàçâàëè ãî çàâèíàãè" àç ïèòàõ çàùî à òîé ìè âèêà çàùîòî èçïèñâà Å4
íî òîâà îçíà÷àâà ÷å ìàñòèëîòî å ñâúðøèëî?! êàê òîãàâà ñè å îòèøúë??????????
ÌÎËß ÏÎÌÎÃÍÅÒÅ!!
ÌÎËß ÏÎÌÎÃÍÅÒÅ!!
translation!
Kan iemand mij helpen? Mijn printer blijft E3 aangeven, dus een papier storing. Maar hoe kan ik dit verhelpen?
En om nou steeds na 1 pag. de printer uit en dan weer aan te zetten is niet een blijvende optie.
Pls. mail me the service manual for MP150.
Regards,
Bhuvan
Regards,
Bhuvan
Does anyone have the service manual for a Canon Pixma MP520? I am happy to download or receive by email. Please click on my username to email me if you have one.
Dave. D.
Dave. D.
I also am looking for the above repair manual.
joe.
joe.
I have it.
hi
i lost my manual fo this printer so ido not know how to use it
could you help in that ???????????????????
feedroller.com
or users manual from canon website
Can i get a copy of the Service Manual for the MP160? Please
How do I fix the E5 error!?!
I'm having a problem with printing. Everything I print comes out very faded and I can't find a way of making the colours come out bolder. Can anyone help? I've replaced both ink cartridges.
soak the printhead in warm water/paper towel. If no change. you need to call canon for new print head.
Nice post, thank you for sharing. You have really imparted useful knowledge. A very useful post I must say. Awesome content. I bookmarked it for future reference.
Thank you for posting the very useful SERVICE MANUAL link. It is still active. There's a big dif between a SERVICE Manual and a user manual. Thanks again for whomever provided a link (versus saying "hey! email me or somethin...as soon as I feel like checking...and emailing...and uh...if I have time...")
Here's the link again. Still active at the time of this post.
Hey, thanks for the tip on the paper jam issue. I'm going to try it!
VM
PLEASE NOTICE THAT XFACTOR ASKS THAT YOU EMAIL HIM FOR THE MANUAL. That is done by clicking on his name. If anyone posts their email address asking to have the manual sent, it will be deleted immediately!
Forum Moderator
Interesting note: In the past 2 years, 126 illiterate people (some so dumb they posted anonymously), who can't seem to understand "deleted immediately" have posted here and been deleted!
Forum Moderator
