norgaard
asked Aug 20, 2006 at 9:57pm
Brother Brother MFC 5840CN
Brother 5840CN error 46
Got an email from Brother that there was a firmware update for my MFC-5840CN. When I went through install step by step, machine locked up and displayed "Unable to Init" - in maintenance mode it gives "Machine Error46" - Support says take it to a service center on your dime - not our problem. Any tips? - I am willing to try whatever to keep from taking it in if possible. I will likely go with a non-Brother if I can't bring this one back online.
if they sent you the email to do the update i'd get on the phone to them and kick up a stink. i assume you've tried a memory clear.
01 in service
by Anonymous on Aug 21, 2006 at 2:21pm Add comment
Here is the answer to your MFC code 46 – happy printing !
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
by trickydicky on Apr 6, 2007 at 11:29pm Add comment
Thanks a ton for your troubleshooting help. Your suggestion worked perfectly !! - Anonymous
Hi Trickidicky or others pro of this 5840CN,
Since you seems to be a pro on this printer MFC5840CN, do you have a trick to turn down the automatic head cleaning process. It runs almost always when I plug my printer and as you know it consume my ink tank.
Thanks for your answer,
Bomi - Anonymous
Hi TrickyDicky,
Please do you have the solution to stop the automatic head cleaning. It is always running when I plug my printer when I print something and as you know it drain my ink cartridge.
Many thanks,
Bomi - Anonymous
Hi tricky dicky,
Just saw your instructions on how to solve the error 46 on an MFC-5840CN. I'm trying to follow the instructions on resetting the purge counter, but it doesn't seem to be working. Just wanted to check that your instructions do relate to this model, as it isn't one of the models you mention after 'purged ink box full'.
When I press menu/set and *,2,8,6,4 I get '4800 BPS NO DET' on the screen or 'procedure RX TE'. Am I doing something wrong?
Many thanks for your help.
by unknown on Jul 6, 2007 at 6:46am Add comment
On MFC-5840, you can start with step 2. 8 and 0 calls direct the log information list.
by unknown on Jan 8, 2009 at 2:50pm Add comment
Many thanks either to trickydicky and ntXsteve for the clue!
I had the same pb on my MFC 5840 and I applied exactly what they said and....It worked perfectly !!!
I can reiuse my printer that I was almost get rid off.
by unknown on Mar 31, 2009 at 1:26pm Add comment
Fantastic! Thanks for maintaining this info all these years. It took me just five minutes of searching the net to find your info, and five more minutes to tap the buttons on my printer, and I am back in service! It couldn't be simpler!
PS: Now I'm assuming that at some point in the future, the purge tray will in fact overfill with ink? Or should the ink evaporate with time? I guess if that ever happens I can just crack the printer open and wash/dry the reservoir sponge myself?
At any rate, I'm back in business, and I don't need to buy a new printer today!
by unknown on Jun 7, 2009 at 12:03am Add comment
Thanks for the tip, I was able to reset my printer which was
showing Error 46.
Do you have instructions on how to open and clean or replace
the purge tray / waste ink reservoir? I cannot find any details
on how to do it either in Brother's manuals or other search
in google.
by unknown on Jun 19, 2009 at 6:55pm Add comment
Hi
Anyone know how to reset the ink level indicators as my machine tells me CYAN and MAGENTA are near empty when they are actually new and full.
And by the way a huge thanks - i too was on the verge of scrappig my printer when i saw the unable to clean solution - worked a treat.
by unknown on Jul 22, 2009 at 7:51am Add comment
print unable 46 appears on my lcd display. Anyone who can help me reset my printer? Thanks! :)
by Anonymous on Aug 21, 2009 at 8:50am Add comment
Re: Brother 5840CN error 46 by trickydicky (4/6/07 11:29 PM) reply + / -
- Anonymous
Dear, everybody
can i know how to reset my brother 150c to clear the error" unable to clean error 46" message
on printer screen. And can i know how to press the combo keys combination clearly
thanks alots for all.
"Please reply me with your kind heart" to my email "[email protected]"
by unknown on Nov 1, 2009 at 1:34pm Add comment
Can anyone help me solve my problem??
i was unable 2 print..
can anyone e-mail me @ [email protected]
"please reply, thnx so much.."
by unknown on Feb 6, 2010 at 1:31am Add comment
Whoever posted this, thank you, it worked great for me, my printer works again!
by Anonymous on Feb 22, 2010 at 9:07pm Add comment
OK...how does one clean out the ink absorber box and where is it located? Thanks so much for posting this!
by unknown on Apr 13, 2010 at 9:12am Add comment
Can anyone help me with error message 4 or 40 on a non fax model?
The message is =no page selected=
Many thanks
Ray
by rayaires on Jun 3, 2010 at 3:53pm Add comment
I have a DCP-585CW. Anyone know how to get to the absorber box please i.e. how to remove the top cover?
Brother and their agents refuse to release this info because of 'Health & Safety issues' or in reality 'pay us to do the job'.
by JUB1L on Aug 30, 2010 at 4:13pm Add comment
hi i have the same error code on a dcp-117c printer but i cannot do the steps to reset the thing. i have tried updating firmware again and everything but when i try to get into maintanance mode and do anything it comes up with 'ADP CHECK P.01' and i have looked everywhere, dont know what it means. can anyone help? thanks!
by unknown on Sep 19, 2010 at 3:54pm Add comment
Success! Took me a couple of tries to hit the actual purge counter - it's the one that says Purge, duh - but it worked like a charm.
by unknown on Oct 3, 2012 at 8:15am Add comment
Hello again. The error on my 5840CN was not a error 46 but a 50. I have tried resetting purge and flush to zeros multiple times, then resetting all the codes to zero, as was suggested, but still no go. I really need my printer to work! Please help!!!
by laleeloo on Nov 5, 2012 at 8:46pm Add comment
Wowww, your instructions were easy and on point. It took me like 2 minutes to reset my Brother MFC-5840CN printer. I started from step 1A because it's the model with the numerical keypad and it fixed my printer. Thank you so much for the posting.
by unknown on Jun 5, 2013 at 6:40pm Add comment
