ozyloco
asked Jul 5, 2006 at 11:08pm
Panasonic Panasonic PanaFax UF-333
Panasonic UF-333
Hi there,
I'm working on a Panasonic Fax UF-333 which is displaying "OUT OF INK" 015 message. I have replace the ink cartridge (compatible) twice which happens to be a HP26 to no avail.
Does anyone know how the machine detects the ink?
is there a way to reset this particular error message?
Thanks in advance
Cheers
Anyone???
by ozyloco on Jul 6, 2006 at 4:14pm Add comment
the error is not with the cartridge but with the ribbon cable which needs replacing, this is known as a flex cable repair kit [(Part code C2144-67902)
by Anonymous on Aug 30, 2006 at 5:50am Add comment
turn the ink test off
function, 7, tel/dail or monitor button 4 times
*, 1 for soft switch
91 for ink test
1 for off i think, but it gives you the options on the display
it works fine without the ink test but you'll have to keep an eye on the ink level
by Anonymous on Aug 30, 2006 at 12:57pm Add comment
