asked Jun 2, 2006 at 12:28pm
Epson Epson AcuLaser CX11N
Epson Aculaser CX11N
I'm stumped !
We have an Epson Aculaser CX11N that is reporting Service Req E537. Anybody any ideas ?
Any pointers gratefully received
TIA
Jason
537 is a fuser failure. You will probably need to replace the fuser to get it going again.
Paul
by Anonymous on Jun 2, 2006 at 2:14pm Add comment
Hi, i got the same error code ie Service Req E537.
Did you manage to fix this problem? If so how? Any ideas would bve welcome!
by unknown on Nov 13, 2007 at 6:33am Add comment
I had to unplug mine from UPS battery backup and plug in into regular outlet. It worked with the UPS for awhile until a few weeks later getting E537 error that wouldn't let machine operate.
by Anonymous on Dec 6, 2007 at 10:26am Add comment
I get a white unprinted band down the side of each page. When I pull out the ckeaning rod on the right hand side there is a patch of magenta toner on it every time. I clean this off and the printouts are fine for a few pages. Then it happens again. Any ideas what could be the problem?
by suepocock on Mar 14, 2008 at 2:22am Add comment
Turn off and uplug the Printer,take out the fuser and clean the belt, replace and see if it works.
by Anonymous on Nov 14, 2008 at 9:36am Add comment
I have two of these printers. One only has 10K prints on it and it super clean. I keep getting an error for door E which is that back panel. I have cleaned and checked it many times to no avail, a tech told me it is probably the sensor that is bad. Can't find a solution.
I have a second CX11NF with close to 90K prints and it prints fine in any color but black. Black has blank streaks from the top of the page to the bottom. I tried all the normal fixes and nothing. Tech thought it was the fuser. I took every toner, the fuser and the photo conductor from the other machine and placed them all in this machine and same problem! I don't get it. I can't think of any other place that could cause this problem.
I really like this printer - when it works. It is rather frustrating to have two bad ones so if anyone has any ideas, I would appreciate it. Thanks!
by sanfranprint on Mar 14, 2010 at 5:34pm Add comment
My wife had a paper jam near the fuser. She decided to "real carefully" slice the paper to help her pull it out. Well, she sliced the black plastic drum cover of the fuser unit!
Is there anyway to separately replace the drum, or must I buy the whole fuser, at about $450 to $500? It would eb cheaper to by a whole new machine!
Any help is appreciated! Thanks, Christoph
by liggy on Jun 24, 2010 at 7:50am Add comment
liggy, Both the drum unit and fuser assembly are only available as complete units. Depending on the provider they could cost $200-$400 each. Hope this helps
by unknown on Jun 28, 2010 at 9:49pm Add comment
Good. where I can get the service manual which specify the various errors that shows the printer. I'm getting this error REG E511.
Buenas. donde puedo conseguir el manual de servicio donde especifique los diferentes errores que muestra la impresora. Me esta dando este error REG E511
by unknown on Jul 15, 2010 at 11:13am Add comment
