ps999
asked Apr 3, 2005 at 3:32pm
Brother Brother Compactronic I
Brother HL-1650 Error Codes
Having spent some time working on the HL-1650, I list below some of the error codes that are useful:-
E50 Fuser Unit Fault
(Can result when the heat roller is damaged or u/s)
E51 Laser Beam Protection Fault
(If you have been inside the laser unit and adjusted the mirrors, beam or not seated the lid properly)
E52 Laser Motor Unit Fault
(As it says, Laser Motor Unit is u/s)
E54 Main Motor Fault
(Motor is jammed or u/s)
S05 Data Bus Error
(seen when there has been a problem with data being sent on Parallel Port - Rebooting the PC often clears this)
Pete
These are pretty much the same error codes Canon uses with the exception of the "E" in front of them. Brother used to use Canon engines before they decided to make their own (big mistake). Their first laser printers were built around Canon toner cartridges, using the same error codes. Later models mostly dispensed with luxuries like display panels and used idiot lights along with separate toner and drum cartridges. Might as well buy a new printer for the cost of replacing a toner and drum cartridge.
by moe on Apr 3, 2005 at 6:19pm Add comment
I have the error e52 being displayed, is there any chance of fixing it myself?
If so How?
Graham
by unknown on Jun 26, 2006 at 4:27am Add comment
error code E52. What is best and cheapest way to repair if it can be done? Thanks - Anonymous
I have the error E52 with Brother HL-1850. Is there any chance of fixing it myself ? And How ?
Thank you.
Philippe - Anonymous
Graham,
I just had the same problem on my HL-1650 today. Coincidence?
Does your printer make a loud howling noise for about 5 seconds and then quiet down and display the E52 message?
I took the printer apart as far as I was comfortable doing, but I never got down to the motor in the middle of the printer that is making all of the noise.
I am going to call the local printer repair company and see what they get to fix this thing, or if they will sell me the part.
My wife found a good deal on a HL-5250 DNT for $262.59 at Amazon.com. I am considering buying it if the repair costs too much. I really loved the HL-1650 and would prefer to repair it.
Greg
by gbrown3 on Jun 26, 2006 at 6:53pm Add comment
I just sent away for a parts manual on CD-ROM for the 1650. I found a laser unit for $125.00 from NESS, their part number LJ5604001.
Does anyone know of another source for the laser unit?
Greg
by gbrown3 on Jun 26, 2006 at 8:22pm Add comment
After receiving the parts manual CD, I was brave enough to take apart the laser unit and found that the polygon motor was causing the loud noise and the E52 message.
Does anyone know where I can buy a new polygon motor, separate from the laser unit?
Greg
by gbrown3 on Jul 1, 2006 at 2:52pm Add comment
Mine lasted longer than yours, lol. It died this morning (7-16-06) with the E52 code.
by Anonymous on Jul 16, 2006 at 9:08am Add comment
Funny that we should all get a failure around the same time. Mine just died this morning (20 JULY 2006). Same thing: loud noise then SERVICE CALL ERROR E52 on LCD panel.
by unknown on Jul 20, 2006 at 6:48am Add comment
Mine too!
by unknown on Jul 22, 2006 at 4:14pm Add comment
I also got the loud noise & E52 error this morning. Has anyone had any luck in finding a fix? I suppose I should start shopping. Maybe these things were programmed to self destrict at a certain time.
by unknown on Jul 26, 2006 at 8:59am Add comment
It must be an epidemic (or the world's strangest computer virus!). Mine went down today with the exact same problem. Has anyone found a solution short of buying a new printer?
by borderland on Jul 27, 2006 at 1:38pm Add comment
And today my HL-1670N have the same problem with (E52) error message but it make no noise, any news about solving this problem?
by pliii on Aug 2, 2006 at 1:03pm Add comment
Our HL-1670N went down with E52 yesterday, also without the loud noise.
by unknown on Aug 4, 2006 at 5:14am Add comment
Same prolem error E52
by new on Aug 4, 2006 at 11:51am Add comment
My HL - 1650 went down yesterday with the loud noise and E52 error code. Is there a solution short of buying a new printer or spending big $$ for repair?
by unknown on Aug 4, 2006 at 12:48pm Add comment
If you read this thread than you can see that the polygon motor is causing this problem.
by spin2 on Aug 5, 2006 at 11:08am Add comment
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
That worked very well for me and my HL-1670n is back to his nice purring noise.
Good luck.
- Anonymous
Can u please tell me Error E51 and the possible solution to fix it
thanx
by sumit on Sep 8, 2006 at 6:21am Add comment
Sorry never got that error (E51). I suspect a misalignment within the laser path. You could open the laser unit (as describe above), clean everything (mirrors and lens) and make sure that the shutter is moving freely (it should open when the printer cover is closed - on the left side, the lid should push open the shutter lever of the laser asembly).
Hope that helps.
by Anonymous on Sep 13, 2006 at 2:42pm Add comment
I replaced the fuser drive gear, and turned the printer on, and got and error 54. I found the main motor connector had come off, so I plugged it back in and I am still getting the E54 error.
After warm up I can see 3 low pulses on pin 2 and 3 high pulses on pin 8 of the DC motor connector. After the 3 pulses the error is diplayed.
Does anyone have any suggestions on what to try.
Thanks Jeff
by jralbrecht on Oct 7, 2006 at 4:23am Add comment
The described fix of oiling the motor shaft worked great for me. Thanks for taking the time to write it up!
I would suggest a couple of changes:
I found it easier to remove the single screw for the small circuit board in the bottom right, and then take the laser unit out towards the front.
I did not find it neccesary to remove the black piece. Simply twisting it 90 degrees was suffcient to remove the mirror assembly.
by Anonymous on Oct 7, 2006 at 1:18pm Add comment
Same error different results, I took everything apart sprayed WD40 onto a clean towel then cleaned the shaft and its entire area, also there was some corrosion on one of the coils [where the shaft goes into, on the circuit board, but i cleaned it up pretty good, Still got Service Error Code E52, When I pressed the SET & Minus KEys it displayed: SCANNER MALF
Any one seen this before?? fixed???
Thanks in advance
by ThomasDean on Oct 19, 2006 at 8:52am Add comment
I don't know what the heck you're lubing with that WD40, but you're not going to fix anything. The 52 error refers to scanner motor rotational speed. It's either spinning at the wrong speed or not spinning at all. You will have to replace the laser scanner assembly.
by moe on Oct 19, 2006 at 9:23am Add comment
ok,
which piece is the Laser Scanner Assembly?
how much is this part?
thanks
Tom
by ThomasDean on Oct 23, 2006 at 8:54am Add comment
Oiling of the laser assembly motor shaft does work. Note however that sewing machine oil is more appropriate then WD40. It helps the motor getting to its necessary scanning rotational speed (less friction). If the symptoms are error E52 and a strange noise coming out of the laser assembly then this procedure should fix it (for a time at least). The noise comes for the vibration of the rotating mirrors that looses it rotational angle, putting a fine layer of oil between the shaft and its enclosure will do it. Might work if there is no noise but if the mirror doesn't spin at all, well... that's another problem of course.
by Anonymous on Oct 23, 2006 at 2:03pm Add comment
I HAVE A BROTHER HL-1240 LASER PRINTER.
I DID AS YOU DIRECTED AND IT WORKED !!!!!
I used sewing machine oil, 10wt 1/2 drop.
YOU SAVED ME $200.00.
I Registered at 3:00 pm.
Tried your suggestion, by 5:30 pm, I am printing again.
Very grateful in New Phila!!
Barney
by barneyh3 on Oct 24, 2006 at 2:29pm Add comment
I have a HL-1870N and it works perfectly also. It takes me 30 minutes to repair this printer and saves me $150.
Thanks you !
nico
by nicolas06 on Nov 27, 2006 at 12:45am Add comment
Hi
I too have a 1870N which has died in similar fashion
Are the steps to fix the 1870N the same as for the 1650....
Would be really grateful for your reply as my printer has done less than 15000 impressions - Anonymous
I have an HL2070N and had this problem tonight - while printing very important banking information, which I had already closed the screen on the PC for. It was very important not to lose this information, so I could not turn off the printer as I would lose the data from its internal memory.
after 10 minutes of pressing the go button and getting angry, I gave the printer a good hard hit, pressed go, and away it went. has been printing again all night no probs :)
by unknown on Dec 4, 2006 at 7:23am Add comment
How do I fix or clean the fuser unit? Do I have to replace it?
by jlc on Dec 7, 2006 at 11:39am Add comment
hi, my printer (HL-1670N) does not display any of these messages, but is doing a strange noise.
The noise is like a little chock in the warm up phase and by printing.
(a white cog wheel on the left side of the printer is moving like it wants to get out ;)
anyone knows what to do ?
by the way, I have to change the fuser unit, how does it works ?
Thank you.
by RipleySW2 on Dec 7, 2006 at 12:39pm Add comment
Thanks so much for this post, you just saved me having to buy a new printer. Kind of fun to perform brain suregry on a printer, too! Only took me 30 min.
by Anonymous on Dec 17, 2006 at 8:56pm Add comment
Thanks very much for this detailed description! It all works together, our HL-1670N is back and we solved once again one of the most urgent problems of mankind: doesn't print...
by Anonymous on Dec 28, 2006 at 6:22am Add comment
It worked for me!
by Anonymous on Feb 26, 2007 at 2:24am Add comment
You are the man
by unknown on Apr 3, 2007 at 7:09pm Add comment
Wonderful instructions! Worked like a charm.
(One detail on my HL-1670: There was a small
sheet-metal tab that held the right-hand cable
connector in place, that slid under the screw
at the right-hand end of the laser cover.)
by Anonymous on Apr 16, 2007 at 12:00am Add comment
Worked for me as well. Thanks a load. Saved me so much time
by Anonymous on May 15, 2007 at 7:45am Add comment
Hi I wanted to thank you guys for posting the fix for this error, but also to add to it. As the fix didn't work for me but I was able to buy a Brother HL1850 on ebay fairly cheaply and replaced the whole laser unit. Problem solved. Plus got good Drum, Toner, and other spares for later
by ex engineer on May 17, 2007 at 4:52am Add comment
This worked for me on an HL-1670N as well. Thanks for the directions. I'll repost them here with my modifications [in brackets]:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side). [Front screws are revealed by pulling open the front cover.]
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one. [Do disconnect the shorter one.]
To do that:
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector. [This was untrue for me.]
[This would not have worked for me, because of a permanently wired cable that went tightly over the unit. Instead, I followed another poster's suggestion and took out the one screw holding the small circuit board in place.]
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back. [I did not see any shutter, nothing came loose.]
2 – Unscrew the 4 screws maintaining the motor section and remove it. [This is not necessary. Leave the board in place.]
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it. [Twist it 90 degrees is sufficient; no need to remove it.]
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution. [Since you have to touch the mirror to lift it, I just cleaned it routinely with an alcohol prep pad after I replaced it.]
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess. [ONE drop of lightweight machine oil. I would advise against WD40, it is a penetrating oil and may not be appropriate here.]
by unknown on Oct 17, 2007 at 4:29pm Add comment
I'm glad I posted my instructions...
Two+ years on, and I get the same error message. This with less printing duty than prior to the first repair. I did the same fix, following my own directions, and it's working again. However, I'm thinking this printer is near its end of life. Bought in 2001, 8+ years service is really not bad.
- unknown
this worked perfectly for me on an hl-1850, awesome, saved me $220 or having to buy a new printer, THANKS SO MUCH, brother itself was of no help and their dealers just wanted to gouge me.
To do that:
[[DO NOT REMOVE THE C CLAMP, PULL UP OF THE HEXEGON MIRROR AND TWIST AS PULLING STRAIGHT UP, THE WHOLE UNIT WILL PULL OUT]]
- Anonymous
Thank you very much for sharing your approach! I just salvaged my 7-year-old 1870N using your lucid technique. - Anonymous
I thought my printer was a gonner. Followed the instructions for E52 and it worked like a charm. Thanks, everyone, for taking the time to put up very clear directions.
by Anonymous on Dec 11, 2007 at 3:50pm Add comment
This message has come out on my machine can anyone tell me if i can fix or do i need to buy another machine? Thanks
by DHR5150 on Dec 19, 2007 at 11:45am Add comment
Thanks for the detailed instructions. My solid printer lives again! The touch of oil was enough to solve the E52 error code and then I received the E51 which I solved by cleaning as prescribed.
by Anonymous on Dec 22, 2007 at 7:42pm Add comment
I called a service shop who looked up the code "EF5" code and told me that this reffers to a high voltage issue. Can anyone help? Thanks for your time.
by DHR5150 on Dec 23, 2007 at 8:41am Add comment
Thanks to anonymous for the detailled instructions. Follow the second instruction set the one with the [] brackets. Just my 50c:
Attention: The mirror unit is actually the Hexagon plate itself!!! When lifting the unit use an optical cloth in order not to smear the reflective coating with fingerprints or scratching it with an unsuitable tissue. So what you want to lift is what you don't want to touch. Using an optical cloth to lift the mirror unit will reduce affection of the mirror unit to a minimum.
by Anonymous on Feb 28, 2008 at 1:03pm Add comment
My printer was working fine until there was a paper jam. I ended up turning the printer on its side to clear the jam and when it was back upright I got an ugly noise and E52 error.
My laser motor was actually stuck - I had to twist really hard to get it to move at all before I could pull the polygon mirror/rotor out. So I cleaned the shaft and bushing with isopropyl alchohl before lubricating the shaft with a drop of light machine oil and replacing it.
It worked like a charm! Thanks for the instructions.
by unknown on Mar 8, 2008 at 6:04am Add comment
OK I need to know who NESS is or a place to find the Laser Unit in the US. Please.
by copyguy1060 on Mar 27, 2008 at 10:05am Add comment
So I got this error and went diving into the guts of my HL-1650 to do an emergency lube job on the polygon motor shaft. (Not as dirty as it sounds.) When I started the machine back up, it whined angrily, but printed. Now I've found a part I seem to have left out, which I think is the "plastic shutter" mentioned here. It's a spindly thing, a right angle of narrow black plastic maybe 2-3 inches on a side, with an upward (downward?) jutting narrow flange on one end that goes off along the third axis for an inch or so.
Where the heck do I put this, and is it related to the angry whine?
Also, when I got to the polygon mirror, there was a bit of hard goo stuck to the top. I wondered how it had gotten there but decided it should probably come off, so I cleaned it up a bit. Now I'm wondering if that was there purposely as a tiny weight balance to make the motor spin smoothly (and QUIETLY) at high speeds. Did I mess up? If so, can I fix it?
Thanks for any help.
by MiracleFlop on Apr 13, 2008 at 5:25pm Add comment
I'm also getting error code e52.
So I tried to put some machine oil onto the shaft, but it didn't help anything.
Sometimes the motor doesn't even spin up :( but sometimes it does, but still e52 than :(
any ideas?
by unknown on Jun 11, 2008 at 7:29am Add comment
These instructions worked great for me. I used oil designed for hair trimmers, which is a very light oil.
by unknown on Jul 13, 2008 at 8:46pm Add comment
I tried this fix, following everything to a tee, but when I booted up the printer, there was that noise and the "Error E52" again. I don't usually do things like this so after putting the printer back together (took me about 45 min) I was ready to be proud of myself, but instead I was really disappointed. I rebooted the printer four times. Same result :Error E52". BUT, on the fifth try, it booted up just fine. Whew! Now I am printing again. Thank you so much. BTW, I didn't have sewing machine oil, so I used some 2 speed chain saw oil.
by unknown on Sep 4, 2008 at 3:19pm Add comment
Excellent directions and a great fix! Works great now.
Thank you!
by bwcc on Oct 8, 2008 at 8:13pm Add comment
I did the fix and it fixed the error code and loud noise . . . BUT now I have a solid black line down any print on the printed side of the page and a fainter black line down the back side. It is about 1/4 inch wide. Any help????
by liestman on Oct 12, 2008 at 4:21pm Add comment
check the corona wire cleaner (a blue plastic slider) on the top of the drum cartridge. it's probably not "parked" towards one side.
by tk55 on Oct 12, 2008 at 8:10pm Add comment
That was it. THANKS!!!!!
by liestman on Oct 13, 2008 at 1:58am Add comment
One suggestion...
After a careful but thorough cleaning of the bearing shaft, I used a light coating of white lithium grease on the bearing shaft. It does a better job of standing up to heat and friction than liquid based lubricants.
by Anonymous on Nov 29, 2008 at 10:30pm Add comment
I would only say that you should use a thinner oil to lubricate your scanner unit. The lube that you used is more for feed roller shafts, gears, and parts of the fuser. that piece is very sensitive to friction and still you might incounter problems down the road becuase of it. I guess if it worked then go for it but just my personal advice to people still reading this post.
by nivek on Nov 30, 2008 at 7:44am Add comment
Greaaaat!
I did what you recommended to do but it is not an obligation to unscrew the 4 motor unit screws, only turn the black plastic rotor retainer for 90° and the rotor/mirror unit comes up !
half of the half of the half drop sewing machine oil in the brass bearing at that's all !!!
Thank's a lot
and a happy new year from France
Pierre
by unknown on Jan 24, 2009 at 7:12am Add comment
Believe it or not...this actually works
by Anonymous on Feb 8, 2009 at 9:48pm Add comment
Regarding section 3, step 3 - "There is a plastic shutter that will come loose. Don’t lose it and take note of its location in case you need to put it back."
This is same piece of plastic that MiracleFlop noted, I believe. I'm having the same issue ... the piece basically fell away from the unit before I had the chance to properly see where it goes or how it attaches. There is nothing obvious that I can discern. It looks like it actuates a lever outside of the laser unit but it's unclear where to position it. Does anyone have further information on this piece?
:::UPDATE::: I just found the slot where this piece goes -- to the left of the hexagon mirror, there is a depression where the part rests ... the swing arm should be positioned on the outside lower left of the laser unit, while the rest of the piece is inside, held in place by two circular-shaped molds -- one large and one small. There's only one way it fits in, so it's impossible to mess up once you find the correct location.
AND the printer is up again working like a charm.
Very helpful thread, THANKS!
by gdguru on Apr 28, 2009 at 4:35pm Add comment
I have the same problem with that plastic shutter. However, I may have a different version of the laser as I can't see any circular shaped molds. Could you send a photo by any chance? I just can't figure this out.
Merle - unknown
Pretty much the E52 is a scanner motor error. Most likely due to wear. You could try reseating connector P12 on the engine PCB or check that 24vdc is going from pin 1 24vdc to pin 2 GRD. If reseating and verifying 24vdc then replace laser scanner. If not you could go further and test the power supply output to the engine PCB. Most likely though your laser scanner just went out. You could also unplug from wall and let it sit for around a half hour to hour and try again. Usually when the motors start to go the machine gets real noisey so if you noticed that lately then thats another sign. Some people on this site fix noisey or failed scanners by lubricating the scanner motor bushings. Light synthetic oil. NOT wd-40. Look through post above for tear down instructions.
by nivek on May 18, 2009 at 11:27am Add comment
I have had our HL-1670 for some years but it's backup printer and not had much use at all. I just can't believe that this unit would be suffering from "wear" as it's only on it's 2nd toner cartridge ever! Upon disassembly the motor seemed to spin w/o any noticeable drag, etc. Nevertheless, I lubed the shaft sparingly with some NyOil (great thin film synthetic lube) and the problem seems to be resolved. So thanks for saving me $200, plus labor fees :) - unknown
I have a HL-1870N which have E50, after changing the fuser it reads E41, wonder whats the problem now? anyone can help?
by Iwin on Jun 21, 2009 at 9:42pm Add comment
Your description(s) as well as a tiny drop of thin oil worked perfectly well for us. Our HL-1670 works fine again. LiamH and all other wizards, thanx very much.
Greetings from Amsterdam, Holland.
by unknown on Jun 26, 2009 at 11:32am Add comment
I haved went by the instructions in this thread and can say that it worked. My printer functions like it should. Thanks to all that posted on this thread.
by Anonymous on Jul 26, 2009 at 1:39pm Add comment
wow! the beauty of the internet...a three year old post helped me fix my Brother HL-1650 printer that we've had for over 8 years! LiamH's extra instructions were right on for my printer. Thanks everyone who posted a comment(even if it was only to say that it worked - otherwise, i wouldn't have tried it and unnecessarily spent $200+ on a new printer!)
by unknown on Jul 27, 2009 at 7:57am Add comment
Another satisfied/thrilled customer here!!! My HL-1670N shut down with a scream yesterday, and I was sure I would have buy a new printer. But thanks to this thread I'm up and running again. (And I'm NOT generally handy with repairs like this.) Excellent instructions and additions by LiamH. Thanks to all!!
by unknown on Sep 21, 2009 at 7:56am Add comment
Hi, I have a Brother HL-3260N and when i switch it on there is an error message " Error E541 service call " Does anybody knew what does it mean and how can i fix it?
cheers
by unknown on Oct 7, 2009 at 12:54am Add comment
Hey guys, I just fixed my brother printer. It had a screaming sound and my model gave me error code 71, The problem was that the polygon motor needed oiling that's all! You have to split the printer to pieces and get to the part where the laser is. Be sure to use a paper and pen and mark where all the cables go and screws so you can put it back together properly. When you get to the part where you open the laser unit. The polygon motor which is basically a bunch of spinning mirrors, that thing needs to be pulled upwards. There is a plastic notch holding it, you can rotate that 90 degrees and pull upward on it. No need to take any clamps off or anything, pull upwards, its held by a magnet. Then just apply a small amount of grease to the shaft area. Lithium grease is a good idea. I used cooking oil, probably not the best idea. WD-40 probably is a bad idea too. Then put it all back together. Do not run the thing with the laser part open. You don't want to get the laser shined in your eyes, that's all bad. Its a small laser beam too, so it may seem invisible. Clean the mirrors! Do not touch them as much as you can. Clean with alcohol if it gets dirty.
Steven J from funny commercials.
by unknown on Dec 12, 2009 at 7:55am Add comment
Many thanks - once I found out where the noise was coming from, Google brought me here and it's printing again.
Happy New Year!
by unknown on Dec 31, 2009 at 5:55am Add comment
I finally found where the part goes! gdguru's explanation is good up to a point. For some reason, I thought the part went underneath the laser unit. Because I turned the unit over when I took the cover apart the first time, I didn't realize the part came from INSIDE the laser unit. Once you make this clear, gdguru's explanation works!
Merle
by unknown on Feb 7, 2010 at 7:19am Add comment
Thanks in advance, I have one Brother HL 5250dn printer giving error E54, any one please help.
by unknown on Feb 22, 2010 at 4:17am Add comment
Five years after this thread was started and another happy camper is added ! My HL-1650 gave me the E52 error (and the accompanying horrible sound before dying) and I was all set to drop it at my local shop. Found this thread and followed the instructions (the later set with additional bracketed tips, thanks LiamH! ). 30 minutes later -- working perfectly!
BTW I used 1 drop of Singer "All Purpose Machine Oil" - purchased at my local sewing supply store (JoAnne's Fabrics on Riverside in Sherman Oaks, CA)
I used a microfiber glasses cleaning cloth to handle the mirror. CLeaned up a bit with a can of compressed air while I was in there. Everything purring like a kitten.
Thanks everyone.
by unknown on Apr 7, 2010 at 5:51pm Add comment
i would like to thank you for your help. We are swiss and i read your help in english with the helpful translation from google. i was reading and my husband made what i said, an now it works very well. thank you so much and have a good time. Loretta
by Anonymous on May 17, 2010 at 1:34pm Add comment
Thanks so much! Model HL-1850 - I started w/E52, and then followed the provided instructions. Next I got E51. It took 3 times to meticulously clean the mirrors and prisms w/rubbing alcohol and voila!! READY! It took some patience but very well worth it. I took the printer off the hands of a client who did not want to wait for a repair. So I’ll see if she wants it back, otherwise I have a new-to-me laser printer, and lots of satisfaction to boot!
by Anonymous on May 26, 2010 at 8:02pm Add comment
Yet another printer fixed. My HL-1650 started making more than normal noise about two months ago. Just recently it would sound like the motor would freeze up on start up and trip the E52 code. The instructions here worked great and the repair was much easier than expected. I used some Wahl hair clipper oil as it was the closest thing to a light oil that I had on hand and the printer is back to normal, much quieter! I must say this has been a great printer, I have had mine for about 8 years if my memory is correct and have never had any issues with a page count of 17,989 on the printer.
Thanks to the folks that posted the fix many years ago.
by unknown on Jun 9, 2010 at 1:53pm Add comment
It worked for me perfectly!!!!! Thanks so much!!! otherwise, I would have spent 200€
by unknown on Jul 9, 2010 at 11:26am Add comment
Outstanding!
The compiled & bracketed instructions covered my HL-1650 printer perfectly.
Even if I have to do this again, easy-enough to keep my trusty Brother printer in-the-game!
Thanks to everyone's contributions.
Scott
by ccoach on Sep 9, 2010 at 10:00am Add comment
It works perfectly with HL 1850. Thanks to all contributions !
by unknown on Feb 17, 2011 at 8:45am Add comment
Works great and perfectly!
So my 8 years old HL-1650 will work still al long time.
Thanks to everyone!
by tilleulenspiegel on Mar 2, 2011 at 10:37am Add comment
Thanks you
Your instructions worked great, got my Brother HL-1650 purring like new.
by unknown on Mar 13, 2011 at 6:45am Add comment
Well, a year after success with the E-52 fix detailed here (singer sewing machine oil did the trick) and the E-52 error has returned, with noise and all.
Sadly, the fix didn't work this time around, even after several tries. Perhaps something else wrong with the laser unit?
So, decision time -- I found a replacement laser unit (PART # LJ5604001) from sparepartswarehouse dot com for $136 plus shipping. Pretty confident that I could put this in, after doing the tear down so many times. But like an old car, is it worth putting $ into an old printer? Who knows how long before the paper drive goes, etc?
Replacement would probably to be a new HL-6050D which would run about $400. (Not interested in the lower priced HL-5370 -- the build quality seems so cheap, and my solid 1650 has lasted almost 10 years!)
Anyone have thoughts on the fix up vs. buy new choice?
by unknown on May 14, 2011 at 12:37pm Add comment
I very carefully followed these instructions and it worked! Thank you, I now have a working Brother HL-1650 for the low, low price of 30 minutes or so of my time and a single drop of oil. Oh, and the tiny bit of alcohol to make sure the hexagonal mirror on the motor was clean.
Thank you, thank you! I thought I was going to have to spring for a new cheap Samsung or some such.
by donnhines on Sep 30, 2011 at 3:01pm Add comment
Hi all, I just followed the instructions and it worked (sort of), the noise is gone but now my pages come out blank! Any ideas on why this is?
by grossetti on Dec 23, 2011 at 8:25am Add comment
Hi All,
I just had E52 show up on my HL 1650 for the first time and my machine was purchased in 2000. Might try repairing it but as someone earlier suggested it might be time to get a new one. I see laser color all in ones for about the price I paid for the 1650. But at the same time it could be fun to try to repair this one.
Thanks for all the insight above.
by unknown on Jan 4, 2012 at 1:17pm Add comment
my printer won't print, keeps telling me to 1.clean corona wire & 2.tone gone,I have put in new toner and cleaned the corona wire thousands of times still getting same message????????????????????
by unknown on Jan 23, 2012 at 9:06am Add comment
I had a very noisy screechy polygon motor. After disassembling the printer I found that the motor easily spun when moving it with my finger.
It must have been having trouble at high RPM (that's why the screeching noise was happening).
I applied a couple drops of 3-in-one multipurpose oil to it, and tried it out.
The motor began to spin and then immediately SEIZED! Now I can't even spin it with my fingers anymore.
The 3 in 1 oil probably wasn't a good idea.
That's ok, I'll feel more confident replacing the motor with a new one anyway.
Just wanted to share what happened to me.
by unknown on Feb 26, 2012 at 6:04pm Add comment
The procedure seems to have done the trick for me. I'll reserve final judgement till I've cycled some jobs through it, but it looks promising.
Thank you to all who posted solutions.
Used RemOil for lube.
by unknown on Dec 16, 2012 at 9:43am Add comment
Thanks so much for posting those detailed instructions for fixing the E52 Error. They fixed my problem, and saved me a lot of money in repair or replacement fees.
by unknown on Jul 21, 2013 at 8:08pm Add comment
Twenty minutes, that includes complaining on Facebook and posting photos that my workhorse 1650 has died and I was 'going in'. Twenty minutes and I was done!
Thanks to Anonymous for the steps, what an easy fix!
Tools needed: Phillips Screwdriver, Needle Nose Pliers, Lint-free cloth, cheap 'drug store' Isopropyl Alcohol, Lubricant (I used Silicon Lube, the kind in a tube that looks like a pen, and fits in your pocket.
Anonymous's steps, with Liam's additions and my additions too.
[Remove Toner, paper tray, duplex tray from back. Unplug the unit. Find a nice flat surface to work on. You're looking to do this in a clean dust-free place. We'll be messing with the optics!]
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one. [Do disconnect the shorter one.] [I disconnected the other cable to the LCD too so that I could place the top cover off to the side. I'd recommend it, if you destroy a wire or connector you're SOL!]
To do that:
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector. [This was untrue for me.] [Me too, keep it plugged in]
[This would not have worked for me, because of a permanently wired cable that went tightly over the unit. Instead, I followed another poster's suggestion and took out the one screw holding the small circuit board in place.] [Circuit board method is the way to go, unscrew that for a little extra play in the wires]
1 - Remove the steel plate of the laser unit. [It's on with clips, pull the plate cover from the black plastic clip on the back right and front left. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back. [I did not see any shutter, nothing came loose.] [I had the shutter come loose on me, it's a little see-saw in the front left of the unit that looks like it blocks the laser signal. Just be careful removing the plate but you should be able to figure it out if you need to replace it]
2 – Unscrew the 4 screws maintaining the motor section and remove it. [This is not necessary. Leave the board in place.] [I removed it but yeah, you don't have to. If you choose to remove it you can pull the cable into the housing gently and unplug it so that you can work on the motor board itself.]
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it. [Twist it 90 degrees is sufficient; no need to remove it.] [It's the Tetris 'L' looking part, twist it to the right or left gently with your needle nose pliers and then gently pull up on the mirror to release it.]
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution. [Since you have to touch the mirror to lift it, I just cleaned it routinely with an alcohol prep pad after I replaced it.] [The EDGES of the six-sided metal plate are the mirrors. Clean them good but only after oiling the motor]
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess. [ONE drop of lightweight machine oil. I would advise against WD40, it is a penetrating oil and may not be appropriate here.] [I wouldn't do WD-40 either, I used silicon lubricant. I coated the shaft, wiped the excess with my fingers and worked that back together. Up, down, in and out. Twirl the motor so it gets a good even coating. Pull it back out again and put another light coat on it, wipe again and re-assemble.
8 - The printer may remember the error code so a power down or two may be necessary. It also seems like the motor takes a print or two to start evening out, so it may be noisy a bit. You may also get dirty prints, print a few DEMO pages and you'll be fine.
by unknown on Nov 19, 2013 at 10:27pm Add comment
Thank you all very much for posting those detailed instructions to fix the E52 error! My old and beloved Brother DL-1650 is now running like new again after following this more then twelve years old thread.
However I made a minor modification of step 2 of part one in the "Step-by-step instruction:
Instead of disconnecting any of the cables going to the top LCD panel, I removed the part of the top cover that holds the LCD unit by unscrewing the 3 screws that holds this part. The screws are accessible from underneath och the top cover.
This might help to reduce the risk of destroying a cable or connector to the LCD panel.
Thank's a lot
and a happy new year from Sweden,
Kurt
by KurtM on Jan 10, 2018 at 3:27pm Add comment
