asked Dec 3, 2003 at 11:58am
Lexmark C750 error
Getting an error message on a Lexmark C750. The message just says tray 1 uncal. Any ideas? There is no number to this error so I cannot find it in the error codes list. Thanks,
Dave
GETTING ERROR CODE " 30 ITU MISSING " ON POWER UP
WHAT DOES IT MEAN.....
Thank
Lucien
by unknown on Dec 31, 2005 at 10:02am Add comment
YOU WILL NEED TO OPEN THE MANUAL FEED TRAY. THEN LOCK THE GREY LEVER FOR THE ITU UNIT. - Anonymous
I have a lexmarkc c750 and it reads 30 ITU Missing.
by unknown on Feb 2, 2006 at 7:45am Add comment
I am getting an error message that reads "136 Service Fuser Error". I do not have a manual since I inherited this printer with my classroom. It is a Lexmark c750. Thanks for any help you can give.
by jpwatson on Dec 14, 2006 at 6:51am Add comment
search for the user manual online.... basically the unit that transfers images has received too much wear and needs replaced. - unknown
you have a fuser assy cam position error possibly engine board issue or fuser, check fuser connectors, change fuser. If this does not resolve more than likly engine board. - unknown
Can anyone tell me which printead 107 SERVICE PRINTHEAD ERROR refers to, black - cyan - magenta or yellow?
Thanks in advance
Lee
by unknown on Sep 29, 2005 at 8:02am Add comment
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
http://support.lexmark.com
I hope this helps
Joey V.
- Anonymous
i know that 106 is cyan. dont know if that helps.
by Anonymous on Oct 18, 2005 at 8:14am Add comment
I can't seem to find my error anywhere on the Net and so far Lexmark as failed to response to my support emails to them.
We have a C750n and the LCD reads "171 service Motor Error" any chances someone know what this means and the recommended service.
by Anonymous on Feb 2, 2006 at 6:57am Add comment
I have a 942 service tmc error on an c750. Can anyone tell me what it means. Thanks
by unknown on Apr 6, 2006 at 10:47am Add comment
Quote from the Lemark Manual:
Tray x Not Calibrated - This message will be displayed when a tray has been detected that is uncalibrated. This message usually means a user-correctable NVRAM problem or the tray was not calibrated at the factory or needs to be calibrated.
Or in plain english you need to go into the hidden menu (Hold down GO & RETURN and turn on the power) go looking for RESET NVRAM, it should be in there somewhere!! Good luck
by unknown on Dec 17, 2003 at 3:53pm Add comment
The message reads "100 Service ITU" HELP!
I just replaced the fuser assembly to remove the last error.
by unknown on Jan 7, 2004 at 12:32pm Add comment
hello
100 service ýtu error help me error log send thanks - unknown
Hi Robert,I have the same problem as you had.
can you help me
Cheers
Frank - Anonymous
You will need to replace the Transfer Belt as well, it will be shoing as worn out in the service counter. :O(
by unknown on Jan 7, 2004 at 4:04pm Add comment
Just remove and re-add the memory stick. That would do the work - Anonymous
Hi Mark,
My name 's Luís and I'm sending this mail from Portugal. I've got a LEXMARK C750 and I'm getting the following error:
- 183 Service / PSD error.
Appreciatte if you can help.
Thank you.
by unknown on Feb 4, 2004 at 1:52am Add comment
The 183 error can be caused by two problems.
1. Sensor Failure (See extract from manual below)
183 PSD Error PSD Sensor error (Yellow) - Replace the Yellow PSD Sensor Assembly.
Note: It is necessary to remove the Printhead Assembly to access the PSD Sensor Assembly, therefore it is necessary to perform the Printhead adjustments.
2. Engine Code Error.
Some of the older engine codes gave PSD errors, but you cannot upgrade the engine code until you get the printer displaying READY.
The part number for the PSD Sensor is 12G6523.
If you require the service manual then drop me a line as it’s 8.6Mb!!
by unknown on Feb 4, 2004 at 1:00pm Add comment
I would really appreciate a copy of the c750 service manual. Thanks - Anonymous
what do the T L R Z mean in the calibration screen
by trevor on Mar 3, 2004 at 11:17am Add comment
can mark please email me a copy of the service manual . PLease
by trevor on Mar 3, 2004 at 11:19am Add comment
I GOT A 150 SERVICE MOTOR ERROR. CAN YOU HELP ME GET RID OF THIS ERROR? THANKS
by OSCAR on Mar 23, 2004 at 5:46am Add comment
Quote from the service manual:
1 Error Codes 150 and 156. These error codes indicate that the Black Cartridge Drive Motor has either failed to lock or has lost lock. Check the Black Cartridge Drive Motor Cable connection to J64 on the Engine Board. Is the cable installed correctly?
2 Check the Black Cartridge Drive Motor Cable connection to the Black Cartridge Drive Motor card. Is the Cable installed Correctly?
3 Check continuity of the Black Cartridge Drive Motor Cable. Is there continuity?
4 Replace the Black Cartridge Drive Assembly. Does this fix the problem?
5 Replace the Engine Board. Does this fix the problem?
Quite a lot to check, but I think your engine board has blown :o(
by unknown on Mar 23, 2004 at 9:07am Add comment
Hey, I recently had to replace the fuser and image transfer belt on my c750. The only problem is that now I'm getting a tray 1 uncalibratied error, but the printer will still print with it uncalibrated. When I go to calibrate it, it gives me the follwing message.
"910 Service
Trans Sensor"
I've been looking for information on what and where that is, but I haven't been having much luck. Could you please help me?
by unknown on Apr 2, 2004 at 7:58am Add comment
The transparency sensor in tray 1 is faulty, I have seen this before with exactly the same result as you. Either you can continue using the printer or replace the sensor (part no 12G6474) but be warned, it's a bugger to replace. If you need instructions on how to fit the new unit please drop me a line. Good luck!
by unknown on Apr 2, 2004 at 8:18am Add comment
Thank you for your help. I'm actually going to need instructions on how to replace the part. So could you please either post them here or sned them to [email protected] . Thanks.
by unknown on Apr 8, 2004 at 6:43am Add comment
Can I get a opy of that service manual for c750 I am having problems with not printing in the middle of the page.
by braniffnet on Oct 25, 2005 at 12:19pm Add comment
Does anyone know what error 147 means?
by unknown on Nov 9, 2005 at 7:45am Add comment
Book says to replace the autocompensator assembly
by dmzcompute on Nov 28, 2005 at 11:28am Add comment
I pickup up a Lexmark C750 the other day, and when I booted it up this morning I got a Error 180 PSD. Thats all I keep getting when I try to print. Any ideas on what this is and how to fix it? Thanks.
by unknown on Dec 1, 2005 at 7:52am Add comment
200 paper jam, clean paper path.
how replase pik up roller and sensor of the same
Thank you.
by alvim on Jan 2, 2006 at 6:10pm Add comment
I have a "36 Printer Service Required" message showing on the printer Lexmark C750. Is there anything that can be done to clear it other than call a service person??
Thanks for any help.
by unknown on Mar 22, 2006 at 8:16am Add comment
I was getting an error that wanted me to change the waste bottle but I did that and now I'm getting a message that reads:
180 Service PSD Error
Help!?!?!
by unknown on Jun 6, 2006 at 12:01pm Add comment
After I replaced the magenta drum, the printer fails to print any magenta.
I tried two drums now, bith the same problem.
The printer indicated that the drum is 100\% full.
But no magenta at all at the paper.
There is no error message.
Does anyone know what is wrong?
by unknown on Jul 12, 2006 at 2:06am Add comment
Hi can someone tell me how to fix error 142 is and how to fix it.
by Anonymous on Jul 26, 2006 at 2:34am Add comment
Hey All,
Our C750 has been leaving color on our printing jobs, so I took out the ITU, cleaned everything up and replaced the unit. Now it will not print on one side of the page. Anyone have any ideas?
by unknown on Aug 18, 2006 at 9:24am Add comment
i facing problem after i replaced new fuser to lexmark c750 but printer still show "80 fuser maintenance" message. anyone can help me? thanks a lot.
by unknown on Dec 22, 2006 at 1:09am Add comment
You need to reset the maintenance count on the printer, press select and return while powering on then go to fuser count reset.
this should resolve your issue
- unknown
Error is a 902 engine error code, what is this, besides an engine error??
by Anonymous on Feb 19, 2007 at 11:59am Add comment
Quoting " Error is a 902 engine error code, what is this, besides an engine error"
Yeah - it is an engine error - in particular an unrecoverable s/w error according to the manual. Engine replacement is unfortunately the only option. I have heard of powering the pritner off and on fixing the issue, but no gaurantee
by unknown on Mar 13, 2007 at 6:50pm Add comment
“I am getting an error message that reads "136 Service Fuser Error". I do not have a manual since I inherited this printer with my classroom. It is a Lexmark c750. Thanks for any help you can give.”
matt
by unknown on Mar 27, 2007 at 2:41am Add comment
by unknown on Mar 27, 2007 at 2:46am Add comment
Hey All,
Check the transfer roller is seated correctly, is it all colours or just one, make sure that the transfer belt is fitted correctly.
matt
by unknown on Mar 27, 2007 at 3:04am Add comment
Hi the 142 error is dc pick motor error replace the staging motor
matt
by unknown on Mar 27, 2007 at 3:08am Add comment
Help!?!?!
You need to replace the psd sensor this requires you to remove the black laser assy replace and\\or clean the psd sensor and refit the black laser assy you then need to align the lasers, unless you know what your doing get a techy to do it for you more because it’s a pain to mess about aligning lasers.
by unknown on Mar 27, 2007 at 3:25am Add comment
You have a yellow tmc switch failure not seen this fault so all I can do is advise you to check the toner make sure its not missing any of the gears, do a motor detect and you may need to replace the cart drive assy. Firmware update could resolve fault.
by unknown on Mar 27, 2007 at 3:44am Add comment
Hey- got a 117 Error-
do I need to replace the Print Head?
Allen
by Allen H on Mar 29, 2007 at 1:05pm Add comment
Getting the following error code 94 after a diagnostic test. Anyone know what a 94 error code is?
Dan
by ddaviau on Apr 28, 2007 at 11:11am Add comment
What diag test did you do..?
you may need to go back in and do a pen line test or something to correct...
by YT on May 14, 2007 at 8:13am Add comment
I have a Lexmark C750 it has 2 error codes: 956 and 960 Can anyone tell me what these are and how to fix them?
Thanks in advance,
Mike
by Anonymous on Jun 7, 2007 at 7:24am Add comment
Hello:
I have a 149 service motor error.
Can anyone help me resolve this
by sumitup on Dec 12, 2007 at 11:02am Add comment
I am having this error too, on my Lexmark C750. Can't find any information on the internet. Would like to fix as I have 2 sets of expensive cartridges I would like to use. the printer displays 149 service motor error. and if the you press the select and return buttons together you get 26 01 L1. If someone could keep me from feeling like I have wasted my money I would appreciate it.
- unknown
Hi everyone, I was wondering if anyone knew what "114 service printhead error" and what to be done? I thinking it might be the cyan cart. because the error pops up when its performing tests and going to blue cart-but I could be way wrong : )
I would much appreciate any help in regard to this.
Thnx in advance.
by unknown on Dec 23, 2007 at 3:42am Add comment
Hi there, any advice would be appreciated, our colour c750 is giving no error messages, but the prints are very grubby, in particular a sequence of 2 black marks together. I have cleaned moving parts but im no expert, any help much appreciated.
[email protected] , thanks Chris
by unknown on Jan 3, 2008 at 4:40am Add comment
I'm getting a "900 Service RIP Software" error when the printer is powered up. Any help would be greatly appreciated. [email protected]
Thanks, Ty
by unknown on Jan 12, 2008 at 7:29pm Add comment
1. Constant "900 Service RIP Software" error.
2. Will print job after you cycle the power.
-What gives? Thanks in advance.
by unknown on Mar 14, 2008 at 2:30pm Add comment
Is there a fix for the 900 Service RIP Software Error? - Anonymous
Pls. flash the firmware engine code or replace the engine board.
by Anonymous on Jul 29, 2008 at 5:11am Add comment
That did the trick. Thanks a million-printer is up and running again.Much thanks.
by Anonymous on Oct 17, 2008 at 12:55pm Add comment
I just replaced 3 out of 4 of my toner cartridges(waiting on the black to arrive) and have most of the "noise" fixed in my printing but I'm still getting some ghosting in the CMY colors and I get a black vertical smudge/streak on the left side of my pages that is there sometimes and not others.
I also replaced the ITU assembly on it.
I'm also getting a lot of magenta when I do a demo print and I suspect that I may have screwed up the toner darkness or something when I was messing around in the diagnostic menus several months ago(it's been sitting a while so I forget everything I did), is there an easy way to reset to factory defaults? I can't seem to find the NVRAM reset so I don't know if that will fix it or not at this point.
I'm mostly assuming that my ghosting is either heavy toner or I may need to re-replace my fuser(I already swapped it for a spare I had a few months back but that may have been the bad one). Is there anything else to look out for?
by Anonymous on Feb 5, 2009 at 2:26pm Add comment
getting the same exact problem, changed the fuser and all the toners, still no solution. If anyone knows a solution please post.
Thanks - unknown
Hi All!!!
I have replaced two toners on my Lexmark C750, right away it started running a line on the side of print job, and then completely stopped functioning and now has a message on the screen
" 36 PRINTER SERVICE REQUIRED "
Would anyone happen to know what it means and how to fix it?
Thanks in advance.
by unknown on Feb 18, 2009 at 3:27pm Add comment
erro 150.10 service motor erro como devo proceder para efetuar o reparo nesse equipamento?
by Anonymous on Mar 27, 2009 at 12:19pm Add comment
Hallo, mein C 752 zeigt folgenden Fehler, 100 Service ITU Error
was kann ich tun Danke
by unknown on Dec 9, 2010 at 12:25pm Add comment
I have several issues occurring right now with my C752 Lexmark printer.
First is that it is now resetting itself quite often and displaying a message saying it is performing a self test. Another related issue is that when I try to print a page it will often get to the point of engaging the paper feed from the tray and then suddenly start a self test without printing the page. Additionally, at times it will start a print cycle, but not feed the paper and go to the self test or go immediately to a series of diamond shaped icons across the panel display that seem to be some sort of glitch or error. All this started right around the time I replaced the cyan and magenta cartridges.
An earlier problem that seems to be separate from the above is that it will not currently print the colors of a photographic image correctly. This started when I replaced the yellow cartridge. It will print a test sheet where any non-photographic text or box will give a clear cmyk color. (I made a test page for this with a box for each color and text for each color.)
As it stands, right now the printer is virtually useless as it will only occasionally print a page without repeatedly turning off and restarting the printer. Even then the printer may or may not throw itself into the self test or odd icon display as described above.
Last, I will need to replace the ITU as it is damaged on one side and leaves streaks down the page of the first ten or more sheets printed. I would appreciate any advice on places to get the least expensive parts available.
by vcorban on Sep 15, 2011 at 10:24am Add comment
I just changed the Fuser in my C752 Printer - As per the manual's instructions I need to access the config menu to reset the fuser count (I currently get the 80 Fuser Maintenance Error) - this is normally done by powering on the printer whilst holding down the setup + return buttons...
This does not work for me. I follow the instructions exactly and release the buttons when the LCD says 'Performing Self Test'.. but instead of then showing the config menu, the printer just keeps on with the self test saying Busy - Fuser Maintenance' then the Error 80 comes up again.. HELP!
Any ideas?
by unknown on Sep 29, 2011 at 2:34am Add comment
@vcorban Sounds like bad power supply. Performing self test & diamonds is indicative of the printer is resetting itself, possibly when the fuser starts to warm overloads the suspected bad power supply. Could be the fuser or RIP as well...
Re: dark streak on the left side of page. This is a bad ITU. If you perform a calibration from the printer menu you see the next few pages show the streak. The calibration drops a band of toner on the ITU, corresponding to the left side of the printed page, and then senses the density of said toner. The issue is the eraser in your ITU is no longer operative.
The maintenance parts in the C750/C752 are quite finicky. I would only buy brand new ITU from a reputable vendor. I've bought "new" surplus ITU that were sitting around for a few years and found them to be defective. It seems ITU have a certain shelf life, even if you call Lexmark they will not warrant it in this case! Figure about $500-600 for a new, non-surplus ITU. I would evaluate the costs because if you aren't printing high volumes you might break even by buying a new machine for approx the price of an ITU.
@Bruce: Should be select+return for the customer menu and go+return for the technician menu. Normally fuser reset is only in customer menu.
by unknown on Oct 5, 2011 at 11:09pm Add comment
107.01.service printhead error
by unknown on Jul 4, 2013 at 12:29am Add comment
-1
171 Motor Mirror motor lock not achieved (cyan).
Note: Do not adjust or replace any printhead before performing checks in “Printhead diagnostics”
It requires special tools so call your local Lexmark ASP.
30 ITU Missing This message is displayed when the ITU is missing.
Turn the printer off, insert the ITU, and turn the printer back
on.
If that doesnt work then try annother ITU.
by jdwvw on Feb 2, 2006 at 9:14am Add comment
There is an ongoing issue with that error message. I have 38 similar printers on my site and it seems that the error "30 ITU Missing" can come up without the ITU being bad, or not in place. I have been working with tech support and they have no answer for this. I have tried 3 different ITU's and the error still comes up. Chances are the locking mechanism associated with the gray arm, is bad, or the connector. - Anonymous
-1
If you press go you should be able to continue caused generally by defective print cart or ITU you might just need to give this unit a clean if dirty
by unknown on Mar 27, 2007 at 3:48am Add comment
