Tomas
asked May 24, 2018 at 1:59pm
Hp HP LaserJet 2200D
Lights error
While the printer are booting for print all lights begin on. When I push the buttons for secondary error code the first green ligth is off. What error is signalized, please?
That's a very common error, the laser scanner has failed. Replacing the laser scanner assembly is not difficult, you basically have to remove the top cover and then the assembly is located right there, with a couple screws and plugs. http://www.printertechs.com/shop/hp-laserjet-2200-...
by ofcourse on May 29, 2018 at 2:55pm Add comment
